1 - 9 of 9 Posts
Thanks to all of you for your help over the past couple of weeks on advice on purchasing my first powerstroke. I will be picking my 96 f250 ccsb 4x4 in a few days. Now the fun begins. I’ve been looking at either the rsk setup or a 05+ swap. With all my research I’m a little conflicted. I Haul small loads around, don’t do much towing, this upgrade is purely for the comfort of my wife and kids. Looks like rsk, v code, sd springs, and shocks will be close to $1500. However, I have a buddy who knows a friend of a guy’s cousin who will sell me a complete 2007 f250 rolling chassis for 700$. Sounds like I would need to purchase shocks for that also. What would y’all recommend? And are there any other added expenses I should be aware of?
Btw, here is my new beauty! So excited.
203089
Project Shamu
Do it right the first time and do the 05+ swap. I've done both and learned the hard way lol
What LtDan said. Do the swap with the links and coil springs.
Great looking truck by the way.
thank you sir. Breaking down the pricing, I was completely wrong about the 05+ swap. Didn’t realize there was a kit to bolt on these suspensions that cost 1300$, especially since I would not be able to do any welding. Then I would have to get new wheels and tires.. that changes everything. Aside from the wheels and tires. Are there any less expensive kits, or a way to piece together my own for cheaper?
Project Shamu
I have made 05+ coil spring swap kits before... PM me.
As far as the wheels go, you can take the hubs and rotors to a machine shop and just have them redrilled for your 8x6.5 pattern if you want to keep them. Thats what a lot of people have done, including myself.
Wheels are crazy expensive these days. I know that is one of the things that kept me from doing the newer axle swap. What did you pay to have that done? If you don't mind me asking.
Project Shamu
I actually did it myself on both the front and rear axle. The rear i was able to strip the hub down bare and put it in our waterjet and blow perfect sized holes in very accurate locations. The front axle i couldn't get the hub in the waterjet, so i made a drill template on our laser and drilled it with a nice drill press. Holding strong and even towed my 22k lbs house (RV) a couple times. No problems.
  • Like
Reactions: lovesdunes
That is awesome!
I'm on the fence with this as well being as I have an 08 chassis already and a set of sd leaf's
as far as redrilling for 8x6.5 lug pattern the 05 axles have brakes too big for 16" wheels so that ruins it for me as I prefer the look of factory alcolas
so curious on what you decide and others peoples opinions as well
1 - 9 of 9 Posts
