1 - 14 of 14 Posts
Justaworktruck
Cummins or 7.3 modifications?
I can buy an 02 SD w 4r100 tranny for $4500. Engine has 30k and tranny 10k. Nothing wrong with truck.
I have an 97 CCSB that I want to build up. I can get a 7.3L w 500hp for around $4500.00. But then I have to buy a tranny for $4000.00 also.
Like
-the sound of the 7.3.
-the "incab" experience of the CR, and it has 350-400hp w minor mods.
Dislike
-Hard to hook up the wiring on a CR conversion,
On the fence with this, what are your thoughts?
Justaworktruck
Discussion Starter #2
"02 SD w 04CR and 4r100 tranny."
Like
Dislike
Either way, you are buying a trans.
Im a cummins fan, but 30k on an engine, even Id just run it.
you wouldn't regret getting the 7.3
30K miles? that's practically new
Justaworktruck
The superduty w the cummins has 30k on it. The 7.3 has 200k miles w 1k miles since being built.
Coal Blower
Buy the 02 SD and 12 valve it. I've got 2 cummins swaps under my belt now. A p-pump and a CR. Although the CR was easy to wire, the p-pump is just a brute of a motor. The p-pump will never let you down. It can also make huge power with simple mods.
Justaworktruck
my biggest issue with the CR is the cruise control hook up.
I could sell you a complete parts truck 97 ccsb with a 5 speed then Ud have everything plus extra parts for ur truck. Engine only has 1 prob it won't start when hot I heard its ipr oring s 199k
Justaworktruck
Deal fell through with my brother, bought the 2002 SD cummins CR w 4r100. Will be going in this winter. HAVE to figure out that cruise control.
For the most part I have donor trucks.
F350 cummins if you still have that parts truck pm me I might be interested considering putting a 12 valve in my 96 dually cc longbed. Going to make it 4x4 first
1 - 14 of 14 Posts
