1 - 19 of 19 Posts
I just put on some 33.12.50 toyo mt's with 18" rims and they are rubbing on the leafs what are you guys doing to fix this, adapters? schwab already put on 1/4 inch spacers cause the right rear blew out my bag 5 minutes after i left.I figured someone has a fix for this.
<---mud
you mean in front? just dont turn so sharp :hehe:
I have the same problem with my 315s
maybe someone has a better idea.
Heck, even my set of old bias Buckshot Mudders on 16x7 factory steel wheels rub the leaf springs, but they are 37" tall. Old bias ply size R85-16, they are close to a 37x10.50-16. Good traction, but they have flat spots when you first start out, especially in the winter.
Wheel spacers are for poor planning. ixnay on the spacers to much crap can happen .
I agree with you on the wheel spacers alot can happen i was just thinken they could be used as a last ditch effort, ive got 38x15.50x16.5 on my truck and they havent ever rubbed, i would be annoyed if they did.
JFURNER77
The bigger the tire size, the more off-set you need in your rims!! I can turn full lock w/ no problem.
I would also be :mad: if my wheels rubbed the springs.
What is your rim back spacing??
jrc
Both spacers and off set wheels put stress on the axle joints. But would you want all of the weight of your truck on your spacers and 2 sets of lugs or on the wheel that fits tight up to the hub? When you buy all 4 spacers for the cost you would just be better off paying a little extra for new rims with the correct offset. Plus you could pick the wheel, plain steel or some killer aluminum ones depending on how much money you want to spend. Price them out.
1 - 19 of 19 Posts
