1 - 7 of 7 Posts
2008 Ford F350 4x4 Crew Cab XL this is the truck im looking at, what is the tallest tire i can run with no lift, and without rubbing issuses. Also without spacers.
the truck has 17in rims now.
thanks
Discussion Starter #2
and what kind of chrome similartors can i get for this truck, the gray steel wheels just dont apeal to me
or would the tires stick out with just a 1/2 in spacer.
i just dont want to tires to stick out past the rear fenders
Beef
Your post leads me to believe you're buying another vehicle and maybe basing the purchase on the wheel/tire combo?
supposedly 35's but if it is a money issue, just buy the truck that isn't beat to $hit and is gonna be reliable. spend $ on rims/tires later after you save up for them. I worked a lot off extra jobs to pay cash for the lift and wheels/tires when I had my 02. I ran the factory tires, one exploded and ran a cheap used tire until i could save up, do it all, correctly the 1st time.
Only regret, not going 8" Icon w/ 37 or 38's vs the 6 supercraplift and 35's, but paid cash for everything. If i can't save up, then apparently i haven't sacrificed for it then i don't need it. No beer, no going out, no movies, no sodas, bs, etc.. Thats how i did it.
Anywho, factory 17's are narrow, 7" mayb 7.5" wide. so even then you wouldn't want to run a 12" wide tire w/o ruining the tread life.
good luck.
Beef
or you could hit the junk yards and get a set of chrome or aluminum factory 18's or 20's, cheaper than new bling.
i was actual steel wheels with like factory stumilators, when it needed tires i was getting black walls. So you wont have the break the tires down when you rotate them.
But i dont want a truck with 4.10 gears i wont ever pull that heavy, the 1 ton truck i was looking at was clean looking no dents or beat to crap. With the least miles it was stull under 80,000.
Most likely ill just buy another 3/4 ton truck.
still havent brought a truck, so bump im still on teh fence
1 - 7 of 7 Posts
