1 - 20 of 25 Posts
hi
after this recent cold, it seems that my truck doesn't turn over as fast as it should. although the two interstate batteries are about a year old, the truck seems to benefit greatly from having a booster applied to the system and then it spins nicely.
the truck is 14 yrs old and the cables look it. i can go oem for positive, start feed and solenoid and maybe napa or such for the negatives.
what are people using for replacement/upgrades for cabling?
Subscribe
I could surely use some too. Out of my 4 connectors, only one of the bolts can actually be turned to tighten or loosen them; I want to replace them before I get them stuck on one of the terminals one day.
Grab some quality cable, crimps and some free time and make your own
2005 F350 CCLB FX4
$140 for all of it from FORD.
I needed starter cable. Bought a Walmart or auto parts store generic 0/2 awe cable around 72" I believe. ToolManGary cut it to length, installed a huge copper ring terminal that he crimped, soldiered, then heated it up to put a 90* bend in so it attached to the starter correct. It was then attached to the bolt on the factory terminal junction.
I say make your own. you can even get better cable that is more flexible and will hold up better. I think its worth the effort.
I didnt replace my battery leads, they are still good. I did however make a custom buss bar setup so I could have a solid positive and ground to hook up all my aux. lights, relays, and any other aftermarket item requiring 12 volts. (Keeps clutter off the battery posts.) When I did that I used welding cable, Ill see if I can get a picture or some more info when I get home. I think I still have a bit left over.
Bobs 7.3
When my battery positive clamps went bad I cut off the old ones really close to the clamp and drilled a hole on the flat part of the metal left there. Got 2 marine style battery terminals with the wing nuts and swapped out the wing nuts for self locking nuts. Applied them threw the hole I drilled and it works great even after 4 years but Id like to make all new wires as there 12 years old and pretty brittle.
It seems like going to the military style would be easier. Then its just a simple crimping of cables, correct? Mine have not failed me but I have those lead caps on top of the terminals for the last year for a good tight fit...I imagine failure is imminent.
Old Yeller, REBORN
The negative cables are pretty straight forward. When I had issues, it was in the connector on the pass side bat, positive lead. I just replaced it from Ford for like $80 for the positive cable.
Bobs 7.3
The negatives are pretty simple but the positive is a bit more to it to get good, solid connections. I dont have any problems at all just would like to make new good ones so I know there changed as I hate being stranded due to something stupid like a battery cable and such. Plus I like creating a better then factory desighn whenever it can be done. My pass side positive was the problem child years ago then I switched that one to the marine clamp and all has been good and looking for a new project for this spring so the pos cable will be one.
'05 Excursion
Companies that put in those punk-azz fender buzzing sound systems use real nice clamps, some even have a digital voltage indicator built into them.
Sent from AutoGuide.com App
try custombatterycables.com the best battery cables out there period!.
Go to Rockauto parts and you can order the whole cable set up and it is much cheaper then ford. It was called starter wire I believe and will come like it does from Ford.
What gauge is the standard factory size as id like to go up one size?
Factory is like 0/1 awg I believe. I was starting for a year with a el cheapo 2 gauge cable. Now have a awt 2 gauge cable 0/2?.
Spins fast as hell, no additional amperage draw.
I like to use welding cable because it's easy to get locally, it's flexible and it has a thick, durable jacket. Crimp and solder the terminals, which are available on ebay if you can't find good ones locally. Obviously look for heavy copper / nickle plated terms (not the flimsy China gold stuff). I like 1/0, it's thick but still easy to work with.
Agree with Van, welding wire is the way to go.
1 - 20 of 25 Posts
