1 - 8 of 8 Posts
my trk stutters every now then diff RPMs and speeds stop by my buddys to nite after work hes got a computer hooked it up and code said TPS where is it and is hard to change, or shld i take it to a g2g an have them do it. thanks for any and all advice guys
Captain Negativity!
You should first spell out words completely.
There is not a TPS. There is accelerator pedal position. Did it say circuit failure or what?
Post the code.
replaced EGR valve and it is still stuttering..... what next, does it need reprogrammed??? thanks guys
codes that are still poppin up are: 0470 and 0488
Captain Negativity!
Check the wiring from the EBP sensor which is located in a pipe coming off of the drivers side exhaust manifold. P0470 is for that sensors circuit. Fix that first.
1 - 8 of 8 Posts
