1 - 6 of 6 Posts
Have an 04 6.0 5R110W and get the OSS code. So far I have checked out the wiring and haven't found any problems there. How do I test the OSS to see if it is at fault?
Former Ford Trans Engr.
There is a spec for resistance across the sensor. That's the only thing you can check. Either the resistance is right or the sensor is bad.
Thanks Mark. What should the resistance value be? I read 0 ohms from pin 1 (voltage) to pin 2 (signal) and 5.5 ohms from pin 2 (signal) to pin 3 (ground) on mine.
Finally found it. Should read 325-485 ohms from pin 1 to pin 2. Looks like the sensor is bad.
Thanks for posting this info! :whs:
I kinda found it accidently. I was looking at the online version of the 5R110 transmission manual to see if there was any difference, and it gave the ohm test value. The printed version that I have has the same picture, but the caption doesn't give the ohm value.
Bought a replacement and now it works great.
1 - 6 of 6 Posts
