1 - 3 of 3 Posts
Emailed Joey but haven't heard back. The oil line that runs from the Remote IPR to the reservoir is leaking and was wanting to replace it with braided SS. I presume if I use the same diameter I am fine. What about pressure and heat? Also would like to replace the HP lines to the heads so they will fit better. What should I use for those?
Greg, check your spam box. I did respond, yesterday. :doh:
The R-IPR is 1/8" pipe and the reservoir end is -4 JIC. The hose needs to be rated 300 degrees and above 250 psi.
Shoot me your address and I'll mail you a new line. :D
On Edit: My mistake Greg.:doh: The email came through a secure server and was mailed back the same way(Tuesday morning). I didn't notice until this morning. Now you have you an email.
Got it. Thanks Joey. The first email came from the firestation, forgot about the server block.
1 - 3 of 3 Posts
