1 - 12 of 12 Posts
my 96 has never ran very warm since i bought i last year. ive replaced the thermostat once(stock) but it still runs cold. temp gauge rarely reaches the "N" on normal. im assuming this is somewhat low, any thoughts?
OEM Moderator
Find a buddy with a IR thermometer or since they are cheap toss a sender in there.
Tom
Demon Dually
They normally run right around the "N" or "O" in normal on our trucks. We have a cooling system and engine designed for medium duty trucks.
Thats how mine was until i put a new stat and sender in. Now it goes into the NORMAL range. Also, do you get hot air when you turn the heat on? Like hot hot?
Banned
the themostat still may be stuck, they sometimes come through "new" that way
tested it in boilin water. Wasn't stuck.
Banned
Banned
Gotcha.:doh:
no problem lol...it's overlooked sometimes as they get dropped as they are being stocked not saying it happens all the time but still
Construction Babysitter
That is how mine was until I put in a 203* stat. Now at operating temp the needle is straight up right between the R and M.
strokefreak
mine stays right around the N-O-R on my gauge. winer time tho in Iowa last year, i dont think it moved at all.
my guage hasnt moved much past the white line and its been in the 90 the last couple of days here, the heat blows really really hot. i havent been driving it for the past few month but i cant remember if it went into the normal range, but the hoses are hot when i grab them. the ebpv valve is unpluged. Do i have a thermostat stuck open?
1 - 12 of 12 Posts
