Tech Support: Yes, ... how can I help you?
Customer Well, after much consideration, I've decided to install
Love. Can you guide me through the process?
Tech Support: Yes. I can help you. Are you ready to proceed?
Customer: Well, I'm not very technical, but I think I'm ready. What
do I do first?
Tech Support: The first step is to open your Heart. Have you located
your Heart?
Customer: Yes, but there are several other programs running now. Is
it okay to install Love while they are running?
Tech Support: What programs are running ?
Customer: Let's see, I have Past Hurt, Low Self-Esteem, Grudge and
Resentment running right now.
Tech Support: No problem, Love will gradually erase Past Hurt from
your current operating system. It may remain in your permanent
memory but it will no longer disrupt other programs. Love will
eventually override Low Self-Esteem with a module of its own called
High Self-Esteem. However, you have to completely turn off Grudge
and Resentment. Those programs prevent Love from being properly
installed. Can you turn those off ?
Customer: I don't know how to turn them off. Can you tell me how?
Tech Support: With pleasure. Go to your start menu and invoke
Forgiveness. Do this as many times as necessary until Grudge and
Resentment have been completely erased.
Customer: Okay, done! Love has started installing itself. Is that
normal?
Tech Support: Yes, but remember that you have only the base program.
You need to begin connecting to other Hearts in order to get the
upgrades.
Customer: Oops! I have an error message already. It says, "Error -
Program not run on external components." What should I do?
Tech Support: Don't worry. It means that the Love program is set up
to run on Internal Hearts, but has not yet been run on your Heart.
In non-technical terms, it simply means you have to Love yourself
before you can Love others.
Customer: So, what should I do?
Tech Support: Pull down Self-Acceptance; then click on the following
files: Forgive-Self; Realize Your Worth; and Acknowledge your
Limitations.
Customer: Okay, done.
Tech Support: Now, copy them to the "My Heart" directory. The system
will overwrite any conflicting files and begin patching faulty
programming. Also, you need to delete Verbose Self-Criticism from
all directories and empty your Recycle Bin to make sure it is
completely gone and never comes back.
Customer: Got it. Hey! My heart is filling up with new files. Smile
is playing on my monitor and Peace and Contentment are copying
themselves all over My Heart. Is this normal?
Tech Support: Sometimes. For others it takes awhile, but eventually
everything gets it at the proper time. So Love is installed and
running. One more thing before we hang up. Love is Freeware. Be sure
to give it and its various modules to everyone you meet. They will
in turn share it with others and return some cool modules back to
you.
Customer: Thank you, God.
Psalm 126:3 - "The Lord hath done great things for us; whereof we are glad."
do I do first?
your Heart?
normal?
upgrades.
Limitations.
you.
