Where are you going to spend some/all that tax money??
  • Interior appearance/improvement mod
    Votes: 0 0.0%
1 - 20 of 28 Posts
Premium Member
Okay post up your plans/hopes for your next purchase for your Super Duty. Remember we have site sponsors and even our own members trying to sell stuff.
Strokin Roughneck
well hook a guy up in the right direction
Premium Member
I can't read minds. What are your plan or ideas? Need suggestions? Simple, mild or wild I got plenty of suggestions.
Strokin Roughneck
500 hp build on a budget. Sorry wasn't expecting anyone to read minds
Premium Member
If you got the funds it's doable. Studs installed already?
Strokin Roughneck
Premium Member
Well the list would read like this: Studs installed (along with assorted updated parts); EGR delete of some sort; ported intake manifold; gauges of some sort; SCT with custom tuning; FICM tuner or FICM tuning installed; Powermax w/single plane compressor wheel; AirDog 150 using a fuel tank sump; modded up-pipes w/ heavy duty bellows; exhaust (Down pipe and cat delete minimum);
Some of these could be combined. Say use a SCT Livewire TS for the tuner and gauges. Get an EGT probe to keep the temps in check.
Strokin Roughneck
Where can I find these items at a good price and which of them could be used parts?
Sent from AutoGuide.com App
Premium Member
Discussion Starter #9
Look thru the Classifieds section down the forum page. The following could be used but you need to be sure of the condition: SCT, FICM tuner, PowerMax, exhaust, modded up pipes.
Unless someone is selling them new "out the box" the others I would suggest buying new.
The section for the vendors is just above the Classifieds section.
Strokin Roughneck
I have a bullet proof diesel half shell I was a little leary of tuning my FICM until I learned more about it but I have a mechanic out of Dallas that does side work lined up to do the stud install on my truck, but we've been talking on what upgrades to do while I have it down for head studs
maintenance parts like an IPR and 2 tires on the rear (oops). maybe ill have enough left over for a forged rod block.
Premium Member
Most everything can be installed after the studs are done. Sure it makes sense to swap out the turbo or mod the up-pipes but they can be done with the cab down later on.
dsberman94: Good deal! Sounds like a good combo of maintenance and mods.
yea. then work my azz of to build the new block. its only money right?
I forgot about finding exhaust butterfly actuators for my diversion pipe too.
Premium Member
Discussion Starter #16
Sounds like some sweet setups coming around for the summer!
Mine was goin be going to some injectors. Now it's goin toward a telephone pole I took out.
Premium Member
Discussion Starter #18
I hope it wasn't too bad of an accident. How about a 2005 front end conversion?? Might as well make it into something good.
I was in my 94 F150. I was coming home from work bout a 500 feet from the driveway, hit a icy bridge an lost it. The sad part is I barely hit it.
Premium Member
Discussion Starter #20
You got to pay for the pole or truck repairs??
1 - 20 of 28 Posts
