1 - 5 of 5 Posts
If you order recons the only difference is the bulb size for reverse lights I put the 08 ups in my 05 which is the same taillight you have, it worked fine but the reverse lights are on the bottom on all the recons so you can order the 99 to 07 the are a perfect fit and look the same
so is the short answer yes those lights on that page will work ?.. im not worried about the reverse ..
yes they will work, why dont u just buy the proper ones for your year? they are like 100 bucks cheaper off that site, slightly different though but not much
fordguyalltheway
because i dont like how small the light pad is .. ive seen these on a truck an there not that big ... i want a bigger lighting area ..... thanx tho
1 - 5 of 5 Posts
