salesman
oke:
1900 for the h2e kit only from swamps and 2400 with the kit and the turboHow much is an H2e mount only kit? And what do you get extra with it that you don't get in the TN mount only kit?oke:
Dave
How so?David I may be wrong but this may be one of the reasons to mount the turbo square.
Do you really want me to answer that? :doh: LOLWho knows maybe my Super Duty's are different than everyone else's
answer all you wantJust looks like the up pipe flow isn't going to be as smooth on the p/s.
The feed and drain can be seen here. They pass through the lower mounting plate at the rear of the block. Same place they are with the original pedestal.How do you all take care of the oil drain and feed's coming out of the block, going to the turbo.
You want easy or do you want efficient power??While the TN is nice the design limits the ability to use different chargers. I'm in no way saying your wrong or your design is flawed. It just appears to me other than the down pipe it's easier to do and there's more room if it's squared.
My base plate sits right over the oil ports. The orings are grooved into block, so there is no need for grooves in bed plate. Then you can simply drill the plate above the supply and return and tap it for npt or your choice of connection.How do you all take care of the oil drain and feed's coming out of the block, going to the turbo.
Yes, stepping the DP works really well.Yes and have you heard that stepping the exhaust is better?
would it be cheaper to go with the hypermax kit and a modded h2e?The only T4 kit in production that I know of is the Turbonetics kit. I have pics of mine in my webshots. The goal is to finally put it on this winter, seeing as my summer was too busy to put it on then. :doh: The kit comes as the mount only (what I have), and the complete kit, with or without a TN turbo.
Dave
