1 - 10 of 10 Posts
Hi kids,
I just put some new AC Delco front sway bar bushings in the I beams of my 06 E350 , they were pretty hard to press in, but the passenger side one just keeps popping out. I thought maybe it was the lube i used so I washed it clean and cleaned the hole in the I beam and just pressed it in dry. It seems to be intact but only lasts a mile or two before it just pops back out again.
Any ideas?
Even after the 3rd install im still using a 3/4 inch bolt and washers and its a hard crank to press it back in...
Im wondering if its under too much pressure, do i need the whole front end lifted to intall them? Im not lifting it at all.
K thx :|
Administrator
i am guessing they are just not the proper bushing
and no you do not have to do anything other than unbolting the sway bar end links to replace the bushings
Administrator
I say post up a pic of what’s going on.
don't play well w others
Older truck. Same idea.
Sent from my SM-G900V using Tapatalk
1 - 10 of 10 Posts
