Just did it on my truck. Had to remove the upper trim piece, then remove the bracket/latch assembly up top. The door will then open with the handle. The latch cable has nylon ( of course ) cable ends that break over time, and a new cable is needed. I was lucky, I just got the one off of my scrapper, and used it. That entails removing both inner door panels, the speaker, removing the cable clip from the center latch assembly, and pulling the bracket/cable out of the top of the door. Then, just slide the new assembly into the top, get a long wire with a hook on it to reach in and grab the cable, then re-attach it to the lever. Piece of cake, 1/2 hour for the whole job. Good luck.
