Hey everybody,
At a loss here
1996 Ford F-350 7.3L PowerStroke (Automatic) - 200,000 miles
I am having what is a relatively common issue when CPS sensors go bad. However, I have tried three NEW Motorcraft sensors and have had no luck. Basically, when I come to a stop OR when I am in park and step on the throttle and come off it quick, the RPM drops to around 500 and then either stalls out or grabs itself. I just had it at the Ford dealership and the tech (who I really do trust and knows his stuff) was at a loss. He just did the front timing cover seal and when he had the engine out, the torque converter was painted and brand new. I also think that since it does it while parked, we can probably rule that out as getting hung up.
BRAND New (all OEM/Motorcraft)
- It pulls no error codes when he had it hooked up. Previous owner had a TPS Tuner in there that we took out.
The only thing that came up weird in any of the scans was that fuel trim were both stuck reading 200%, which obviously makes no sense.
At a loss here
- All 8 Injectors (Stock), this week
- Fuel Bowl
- Fuel Lines
- Oil Lines
- HPOP
- Front
- Timing Cover Seal
- BARO Sensor
- ICP Sensor
- EOT Sensor & pigtail
- IPR (No rebuilt), new
- ECT Sensor
- EBP Sensor Tube
- Alternator is reading fine
- Both tanks of fuel are full and sending units are working fine
