1 - 6 of 6 Posts
i just changed my oil a few weeks ago and now it seems to foam pretty easily. by that i mean if i turn the chip up and romp on a little it starts to hum at an idle. I used rotella 15w 40 just like i always have with nothing added. it even did it after a few minutes in high idle, i just don't get it.
any ideas?
Discussion Starter · #2 ·
is there anything else that could cause the oil to foam. ie somthing broken or not running right
Discussion Starter · #4 ·
i see some bubbles on the dipstick but i don't know what to compare it too
could be a o ring on a hpop line sucking air they will suck air before they will start leaking....
Discussion Starter · #6 ·
i'll have to check on that, thanks. I was suspicious of the oil because it seemed to start shortly after i changed it but i couldn't imagine why
1 - 6 of 6 Posts
