1 - 4 of 4 Posts
Yesterday, my '00 F-350 started running poorly and stalled. Would not restart. Was late enough that I threw a new CPS in her, then gave up when she wouldn't restart. My generic OBDII scanner wasn't reading at all. Will get a friend's help pulling it home tomorrow, and have ordered an AutoEnginuity with full Ford enhancements. Scanner won't be here for 3-6 days, though. Anything anyone else would suggest looking at, or trying, while I wait for the scanner?:confused:
Check fuel pressure, pull the valve covers and check that the harness is fully plugged in, check the ICP for oil under the harness.
Really unlikely for both UVCH to be unplugged, but those other ideas are good. Thanks.
Discussion Starter · #4 ·
Well, I discovered I fell into the idiot trap. Went back the next day, found low oil and filled it. After a little extended cranking, she fired up. :rolleyes: I forgot that while I was out of town, my truck got taken on a run to move my stepsons heavy toolbox. I didn't think I had driven enough to drop the oil that much, even with the moderate leak. But factor in the extra trip, and that did her.:doh:
1 - 4 of 4 Posts
