1 - 9 of 9 Posts
Howdy everyone,
I could really use your help on this one. I recently acquired the stock Alcoa rims for my 1997 F-350, here's the problem. Can I use the first type of lug nuts that I've attached or do I need to use the flange type lug nut? The markings on the rims indicate that a flange lug nut was used, although the holes look like they have a chamfered edge that would accept an acorn type lug.
As I understand it, these trucks are Lug-Centric from the factory meaning the lug nuts center and support the weight. That being said, I am still unsure if it is safe to run this type of lug nut, I have seen a few pictures where it looks like the same or similar lug nuts to mine have been used but I can't be certain.
Thank you in advance for your help.
Matt
Discussion Starter #2
For some reason it won't let me edit my previous post. I posted a picture of the lug nuts I have but it's not there now.
Here's a picture of what I have and am trying to use on the stock rims. What say you guys?
Both my trucks have used the flanged nuts (both with factory Alcoas). Cheers!
Thank you for the help guys. I take it it's probably a safety concern in that case. Does (btdt) mean been there done that ? In any case it might just be better for me to get the originals. They are definitely pricey though.
Does anyone have a lead on where I can find some stock lug nuts for less than an arm and a leg? The prices are insane from what I've seen.
Thank You,
Matt
the factory lug nut for the obs (single wheel) is an acorn shape nut like the chrome ones you showed
Right on Josh, I appreciate the response. I was skeptical at first with going with them, but it looks like I'll be okay. I don't have the hub covers so the longer acorn type should work just fine.
Discussion Starter #9
Just spun a lug nut off one my '97s w/Alcoas that I've owned since new. Both trucks use the same lug nuts.
Acorn
Beautiful. I cannot tell you all how much I appreciate your help, though a very basic question, the tire shop planted a lot of doubt in my head that was now clearly unfounded. Pictures can be worth a thousand words.
1 - 9 of 9 Posts
