1 - 3 of 3 Posts
I have a 96 F350 this is leaking fuel from the drivers side exhaust manifold. It runs real rough. I noticed the exhaust manifold does not warm up unless I hold the throttle wide open for several minutes. The truck has new injectors in on that side of the motor as well as glow plugs. Has anyone else had this problem or an idea of which way to go from here, I don't want to keep throwing money at this truck.
Where exactly from the manifold is fuel leaking out?
The only way fuel would ever have contact with the manifold would be a leak somewhere else running onto it, or a cylinder that isn't firing and fuel getting inside the exhaust on the exhaust stroke.
What csp said, is it coming out of the manifold its self or running down onto it? is it towards the rear, front, or center of the manifold? If its towards the rear, it might just be the feed from the pump spraying onto the manifold, and possibly causing low fuel pressure/aeration of the fuel on the bank, but that would entail a pretty huge fuel leak
1 - 3 of 3 Posts
