1 - 3 of 3 Posts
Hi guy's is there a products that can help or clean or lubricate vanes on my turbo that exist and where it should be ingest to really make difference
When I did mine I went on to you tube before I tackled it to see what I was getting into and different ideas the best way to clean you turbo is to remove it and I used carb and choke cleaner with a wire brush
Then is the other part the ring that holds and controls the veins might have signs of ware that could be causing the sticky problem your talking about with it just being filled with gunk but going you tube is there is a video of different tricks getting the turbo out and back in when I did mine I broke my up pipe getting it back in so if you hear a really high pitch wisle that would be it
Sent from my moto g(6) forge using Tapatalk
1 - 3 of 3 Posts
