1 - 6 of 6 Posts
amos moses
Hi i am currently doing an egr delet,studs, and an oil cooler rebuild. can anyone tell me how to identiify if my truck has the updated stc fitting on my hpop? pics would be great also. thanks in advance.
geoff
amos moses
Discussion Starter #2
Anybody?
what year is your truck and has it ever been serviced by ford for a related HPOP problem before
it's an 02 05 08
remove the ipr,take the pump cover off,on the back side of the hpop you will see the fitting if it is a one piece tube youre good, if it is two piece it wll have a rubber like quick connect on the tube,heres a pic of the updated fitting
amos moses
Truck is a 2006 build date is 11/05. Truck hasn't been to the dealer since I owned it. Not sure about before then. Thanks for everyones help!
then you have the bound to fail stc snap to connect coupler install the new one peace i have a 05 that had a no start at 100,000 this was the problem i installed it now runs fine
1 - 6 of 6 Posts
