Ok, I started the upgrade on my fuel system this afternoon. I was just gonna fix the fuel gauge sending unit, but I was already in there, so...
I pulled the bed loose and jacked it up since I had no help to drop the tank. Worked great, till I had to run the fuel line. Maybe I should have went bigger, but, I ran 3/8 pickup to 3/8 line--into a napa pre=filter/ water seperator. Then on to a second pump I robbed off the bronco II....:lame:.
Sposed to be a 350 lph @70 psi pump. I know it will put out well over 100 psi , cause I broke the fuel pressure gauge on the little bronco messing with it. Ran it from that pump on to the stock pump. Temp. wiring till tomorrow on the new pump. Havent had a chance to try much since install.
Let me say this.---That stupid plastic nut that holds the pickup/ sending unit in the top of the tank is a &^^%^^^*&*766545576*&^%7 mofo to get back on a started!!! Took me at least an hour to get it back on. Where are most of you pulling power from to the pump? I dont want a rigged up looking bunch of junk, I'd like to not even see the wiring. Will be putting a gauge on tomorrow to see what its doing, hopefully its holding, and I can shim the regulator to somewhere around 65 psi. Got pics, but havent taken them off the camera yet. I didnt realize the stock lines were that small.
