1 - 20 of 24 Posts
ok here is the kicker, has anyone done a 4x4? i have looked all over to see if this is even possible. any input appreciated
i never knew, i would like to do this, it would be something like hotrod tractor's project. any more info on this?
Attention Whore
Weweld built one for John Wood. PM him for info.
thanks for the link
i think i can handle it, i would start with a 4x4 first though. i looked through the pics and readings and it was not very much detail
this project will be similar, but use a '77 shortbed body and not be as high
07FORD250 short bed.jpg I was just looking around for a place to post this Pic. Me and my dad built this truck a few mos. back 07 250. We had to use a 01 reg cab shortbed f-150 fuel tank. Every thing else was pretty straight forward fabwork.
I think i got a few more pics somewhere, ill try to find them. The truck came in and we had a white shortbed so w/ jumped on it and had it tore apart and the frame cut before I really even thought about pics. We are really bad for that never take many pics of projects.
OBS junkie
I heard that the short bed 4x4 can get wild if you launch em in 4x4. Anyone here ever play with on on the performance side of things?
HP Junky
Is this only true on the 4 wheel drive trucks or is it true for all Regular cab short box conversions?
I think it's only the 4x4 trucks, the transfer case causes clearance issues. I think when short bedding a 2wd, you just need a standard short bed fuel tank.
Discussion Starter #19
that is exactly the info and pic i was looking for thank you very much, any more pics would be awesome
I def will try to get a few more pics. up the only other thing we custom made was we silver soldered a fuel line up and moved the e-brake bracket and re-welded it to the frame. Its been a few mos. now but if I remember anything else Ill let you know. Hope this helps
1 - 20 of 24 Posts
