1 - 2 of 2 Posts
Anyone know it to be harmful to use stainless gaskets in the brass sleeves?
The last orings I installed had stainless and I thought nothing of it, maybe an upgrade?
Today I found info that says they belong in stainless sleeves only.
green member
If the o-ring kits you used had steel chamber gaskets they were for a DT466E or 530 which used steel cups.
If the different materials don't seal and you leak compression by....the injector should be rebuilt with a new tip IMO.
If they were mine I'd replace them.
1 - 2 of 2 Posts
