What/who's HPOP are you running then to support your stage 2's then? I don't see it listed in your sig. Are the thrust bearings different on the H2E than the D66?If you plan on a D66 in the future I wouldn't get teh II's . II's will require a bigger more capable turbo. I have an H2e with II's and it is a good combo for towing.
The D66 has the same bearing setup as a stock turbo and will not hold II's.
If you want II's and want to tow with them you may want to to replan your setup. IMO only, I don't feel the adrenaline will get the max ability out of the II's either. Just my opinion based on my experiences. I was gonna get an adrenaline and realized it wouldn't support a big set of II's as well as I thought.
He must be running split shots if adrenaline wont do the job.What/who's HPOP are you running then to support your stage 2's then? I don't see it listed in your sig. Are the thrust bearings different on the H2E than the D66?
Sweet, as I need to keep the truck as reliable as possible and beable to haul my mud truck(about 12,000lb).No, you will be fine with stage 2's and a D66.
Hundred's of people have that setup and they aren't complaining.
Stage 2's have been dyno'd over 450 hp
Adrenaline would be a great pump for Stage 2's. Or for cheaper just get a modded 17* HPOP.
You would need to get electric fuel system, better clutch.
If i did my setup over again i would go with stage 2's
Here is the setup i would go withSweet, as I need to keep the truck as reliable as possible and beable to haul my mud truck(about 12,000lb).
Im wanting to push for 400hp-450hp.
I'll probley go with the adrenaline, not to bad of a price.
yea going to work on e-fuel system and understand need better clutch.
So a D66 plus adrenaline will work with stage 2's and not get to hot?
I was gonna say. I just put my adrenaline in about two weeks ago and it made a huge difference over my old worn out pump. My plans are to run 2's and a D66 with custom tunes with the rest that is in my sig. Also looking into intercooler that I can plumb without cutting my brand new from ford rad support. I have a 3" body lift so I think I can tuck the tubes around and under the rad support if I get the right one. Sorry for the derail/highjack OP.He must be running split shots if adrenaline wont do the job.
Well I was running a modded TE pump. Just took it off last night. I have a Termy Dual pump system on the bench going in this week.What/who's HPOP are you running then to support your stage 2's then? I don't see it listed in your sig. Are the thrust bearings different on the H2E than the D66?
Split shots would be easier on a pump. They might even be able to be run with a good 17° pump. Mine are 180cc Single shots. Single shots drink ALOT of oil, especially the bigger you go.He must be running split shots if adrenaline wont do the job.
TE now charges $100 to mod a pump I believe. He used to be cheaper when it was new and he was still data logging it. I think now that he has plenty of data and support to back it up he now sells the newly designed modded pump.What does the modded TE cost anyways?
How has the 97" been driven? Does it tow? IC? That's the set-up I want for the green truck but was worried it wouldn't be enough.I love misinformation on the internet its what all the cool kids are doing these days.
Depending on the size a split will always use more oil then a single shot. Since you have 180cc single that is the same size as a AD split shot but larger of course then most standard 160cc singles.
We use D66's with Stage 2's all the time, like someone else said hundreds of them. Its not about the turbo not being tough enough to support it it is more about the tuning and the pedistal. With the wrong tuning drive pressure can get out of control and that will kill a turbo. We have also seen ebp solenoids mess up and starve the turbos for oil. Since we have started doing our own tuning and selling nonebpv pedistals our failure rates on D66's have gone down to almost none over the past year and if there were any failures it was'nt with our tunes. We have even gone to pairing up D66's with 238cc hybrids now, just tuned a 97 in on the dyno at 530hp with that combo. We have a few others that have been running a D66 with 238's for years.
So with Stage 2's get a intercooler, D66 and some good tunes and you will be able to tow anything you want. Matt here at the shop has that combo and he tows his camper in our Hot tune that makes damn near 400hp and never gets over 1200 degrees. In our lower tunes like a tow program it wont top 1000.
