1 - 4 of 4 Posts
08 6.4 73K Ive been listiening to my belts squeak all winter long and im tired of feeling like im driving a beater with all the noise. Every Youtube video i looked at, it seems that you have to take the front end off of the truck to get your hands on anything. haha NICEE. If I Take it to the shop its $700 if i replaced everything plus labor.
Words of advice and/or youtube links of advice.
Thanks Guys
Gone Broke
From past experience that's pretty much your two options... Nothing's easy or cheap on these. You make wanta look closer also, I had a broken idler pulley on my first 6.4 and it sounded just like a normal squeak till I crawled under and seen it was broken and rubbing!!!
09 6.4
$700 to replace what? the belt? i'd tell that place to fly a kite....
if the egr coolers are still on the truck it makes things much harder...but still doable in under an hour. i would recommend replacing the main belt tensioner for sure while you're at it.
Put some soap on it until you have time to fix it
1 - 4 of 4 Posts
