1 - 20 of 21 Posts
StackinChipsLikePringles
No, but custom tunes are in the work from RCD
The new dude
I drove a customers truck yesterday with just the tier 1 license. What ever the high HP tune in that is has some awesome trans tuning. It shifted really good. Almost as good as the built Allison behind my Duramax does. I will say I was pretty impressed with it. Not sure it needs any custom tuning.
WOOOOO!!!!!
I agree, the 250 tune I have shifts amazingly well. I'm going to update to get the bigger tunes but I plan on running the 250 tune 90% of the time.
That's what I said...........till I sampled the 300 tune. There is no going back, you'll see.
How well does the trans hold up to thew 310 tune say if your on it say about a 4(out of 10) DD and get maybe as agressive as a 7 or 8 just messin around? I havent gone above the 275 for this reason....
What do you mean? There is transmission tuning, yes. Are you asking if you can change the tuning yourself via the DashDAQ? If so, the answer is no.....for now.
For now? your keepin stuff from us jeff lol being able to adjust things like converter lock-up would be sick
If you use the power wisely, you should be fine. There are a lot of people who have daily driven with our 310 tune for thousands and thousands of miles on stock transmissions with no problems. It's a big tune though, so stock parts won't last forever.
Hopefully the big DashDAQ update we are working on with Drew Tech will offer something like that. It's not for sure what all will be in that DashDAQ update though, so I don't want to say it will happen.
Any chance of being able to set defuel limits with the new DashDaq firmware?
The 275 wont defuel Jeff?
Hmmm, A buddy of mine was having problems with his defueling or that is what it felt like to me, moved the numbers on all his gauges to what i thought would be a good set point, it was set pretty low, and seemed to cure his problems?
Ahhh I really aint sure then Jeff.. I thought the high warning was an alert sound and high limit was defuel limit.. I tried LOL
Did he switch tunes without doing a trans relearn? I had my truck defuel once on the 275 but after talking with jeff and he suggested that I've never had it do it again
man control over stuff like that would be sick!
1 - 20 of 21 Posts
