Cruising down the road yesterday morning and the truck suddenly drops to an idle..... had no pedal what so ever for about a minute then it just died and rolled to a stop ! Wouldn't start after that. It sounded as if it wasn't getting fuel. Towed it home.
I changed the fuel filters this evening and after many tries got it to start. It started very slow like it wasn't getting enough fuel. After a couple seconds it idled pretty decent but still has no pedal..... just idled no matter what you did to the pedal. It's about 50 degrees out and it did go into the higher rpm idle for about 2 seconds then it backed right down to the regular idle rpm and sounded like it was going to stall again.
It is throwing no codes according to my Edge...... any ideas as to what's going on here ? Possible fuel pump ?! I have no fuel pressure gauge and the truck is stock !
