1 - 4 of 4 Posts
if my trucks in 4x4 and i get on it. on the drivers side it sounds like something isnt catching or is lose and wobbleing. any ideas what this might be? I dont think its the whole front end but deffinatly the drivers side.
Diffrent Strokes
Sounds like the universal joints may need replaced. Grab the half shaft where the u joints connect the drivers wheel and see if it has excesive play. Also may want to jack up the wheel and check for wheel bearing issues.
I'm not a Newb!
x2 on the u-joints. Also there may be a bad needle bearing for the outer axle and the hub is not engaging.....
ill check that this weekend. i was thinking it was just the u joint but wasnt sure. Im getting ready to do ball joints so i guess ill be doing the u joints at the same time.
1 - 4 of 4 Posts
