1 - 7 of 7 Posts
Hey guys I have a 2005 6.0 and when towing at about 40 -50 for about 15-30 minutes the little small wrench light comes on I have read it is the throttle position sensor any help please and thanks.
"resident smarty pants"
You need to have the codes scanned. Many times (when you get the wrench light while towing) it is an overboost or a warning that your oil cooler is plugging.
The cooler was replaced about 30k ago the other symptoms is when you want to give it some gas it smokes but just creeps slowly when you are going about 40+
i like to party
get it scanned by someone who has a quality scanner...
I keep getting a constant wrench light for the TPS, And I replaced the pedal assembly already, its a pain in the ass. Must be a short somewhere, i need to replace the harness
You will still have a stored code (assuming you are using the right scan tool) ...................
1 - 7 of 7 Posts
