1 - 11 of 11 Posts
06 f350 with leveling kit, 35" mickey thompson atz's sct programmer and 5 inch exhaust. What are some small things i can do that will improve the pull? Arent allowed to hang weights off the front end.
Busy Busy
Traction bars, take the leveling kit off, drop to 33" tires, move your hitch forward, block your suspension....
the leveling kit is just a spring spacer, that will hurt?
Does this mean no weight bar? Can you bolt some weights to the frame?? You need to get the weight as far out in front as your rules allow........Truck pulling is all about geometry...........the way you have your hitch built and mounted can make a huge difference, sounds crazy but you want it attached to put down force on the front end of the truck.............
no weight bar, ive heard of people hiding weight in the engine bay under batteries, behind radiator, etc.
1 - 11 of 11 Posts
