1 - 14 of 14 Posts
Sometimes my 2-3 shift is sloppy, almost like a shift flare. Anyone else notice this? It's on the 310 low response tune. Doesn't happen all the time tho. Does reloading the tune help? Thanks.
WWDD
mine does it too, usually if i go from driving hard to driving nice, or vice versa.
IM OUT!!!
Does it happen before the converter locks up?
mine does it too on the 310 mild
IM OUT!!!
i notice it around 45, right before converter locks...seems like the TCM trys to shift and lock at the same time? it does a slight bucking, its only happend 3 times and only while city driving.
the 2-3 also seems like it stretches to 3000 or a bit more before shifting?
I believe the 2-3 shift is the only shift that uses a band in the trans for that shift it always feels a little different more noticible on the bigger tunes tho.
Has been happening to me everyday with the 310 low response. It will shift fine until its warmed up:confused: After getting off the freeway it will start the 2-3 shift flare between stop lights.
But if you put your foot into it it obviously shifts nice and firm but the poor people behind youLOL
if you were to put a spartan tcm in would it fix it?
Im running the spartan tcm. Have done the relearn process a couple of times now. NO DICE !:doh:
I feel the same 2-3 shift on the 310 and SCT from Eric. It only does it if I am very light on the trottle and barely accelerating. Any other time unnoticable.
Discussion Starter · #12 ·
Thanks guys. Nice to know it's a common thing. Mines the same, only does it under light throttle sometimes.
well at least I kind of know why it is doing it.
1 - 14 of 14 Posts
