1 - 13 of 13 Posts
I am debating on lifting my truck, I would like to see some black single cabs lifted. I would like to run 35s.
Discussion Starter #2
After reading some i think I could just get a leveling kit. What is your guys opinions? I would just like to clear a 35 or 315/75/16.
I have a leveling kit on my 2wd with 35.5's ... 325/45/24 I get a very slight rub on the plastic valance
Side view
So you think with a leveling get I could clear 35s?
I don't see why not, you will have to get an alignment and probably need new cams so figure that in also.
What are you calling cams?
Discussion Starter #9
Will the shop have them when I have the front end realigned?
Mine took 3.25 degree cams is your truck I beam or leafs?
It has the leafs. From my understanding it has the dana 50.
I don't think you need to worry too much about the cams then I have ibeam setup 2" lift tweaked it a lot, not so much on a leaf spring model basically you going strait up
1 - 13 of 13 Posts
