1 - 20 of 23 Posts
I found an 05 king ranch today with 136,000 miles. The no.2 piston is scored but I can get it for under 10,000 I think. The body is in great condition(white/tan) and my friend will rebuild the motor with studs, egr delete and injectors for 5k. Would make a great farm truck I think. Thoughts? Deal or not?
__________________
there is a place out of ten. that is selling rebuilt 6.0s with arps and other stuff for 4000.....with a 12 month unlimited mile warranty
add a oilcooler delete, i had the same mods, everthing was good there i just blew a oil cooler 30,000 miles later, buy it if anything you will get ur money out of it again parting it out
Stroke it B!tch
Im sure you could have one built with oem gaskets......
Administrator
True
I wish the google search turned up more info
even a google map turns up a house i think ?
did you try to call them?
I would buy it at the very least you could fix it and flip it... If your friend is going to do all that work I would rather give a buddy money to fix it than someone you don't know...
Well typically his buddy won't be halfway accross the country... But usually if a friend does the work than he will stand by it (I know that is not always the case)
Administrator
Tough call
but parts fail just like the on going Headgeasket discussion
should your buddy fix that ?
Tough call
I was torn with my latest repair. My good friend did the work with the parts I supplied him, so when the gaskets failed, I ate it, didnt even mention it to him, because its not his problem. now if I had bought this engine and it had a stated warranty, you bet your but I would have them fix it.
Administrator
Thats what I am talking about right there
tough spot to be in for sure You want to help a buddy but at what cost
If it is clean I would buy it..
I agree with this, but I would buy the truck, pull an OASIS report on it to check other history first.. That trucks books for $20k-$24k,.
Administrator
I think it has potential also but for a Farm truck???
I am no farmer so I may be clueless but it seems like a nice truck to run Fields in ??
If the truck has a motor that needs rebuilt it is only worth about $8k tops. I wouldn't buy it for a farm truck unless I could get it for $5k. $10 is way too high.
1 - 20 of 23 Posts
