1 - 5 of 5 Posts
I found the spec on the hub bearing load it was for a d50ttb axle though. It said torque the lock nut to 50 ft lbs and back off 45 deg and install the lock washer and 2nd nut and torque to 150 ft lbs. Does this sound right to you guys?
Demon Dually
That is correct. The trick is to rotate the hub/rotor assembly when torquing to 50 ft lbs though. You want to make sure that the hub is seated correctly when torquing in order to prevent premature bearing/seal failure.
Yup did that 2 just forgot it. I wanted to make sure it was right the bill is up 2 like 2k on this project not really up for extras :)
THE ONE AND ONLY!
Yeap....done this probably quite a few times....never had a failure....:ford:
1 - 5 of 5 Posts
