1 - 4 of 4 Posts
I took the ts 6 pos. out of my truck to get a dp tuner finally. but now with no chip on the pcm just the edge juice on 4 it throws the light. No loss of power and it will eventually turn off just annoying to see on, any thoughts??
<-- it's like that
How long before it turns off? 30 seconds? 2 minutes?
Without reading codes, it's just a guess. But if the CEL shuts off after 30 seconds, then it's typically an overboost code. If it shuts off after 2 minutes, it's typically an oil code (p1211).
It stays on for awhile, but if I stop and leave it running when I like run in the house or something it will shut off when its just idling after a few minutes:confused:
What Pocket said, if you pulled the codes it is either overboosting, Do you have gages? (I HOPE?) LOL If your punching past 25 or so, it's overboost. WOT runs could be either though, ICP higher/lower than desired, (Probably lower than the Edge is asking for.) Either way, it's normal.
1 - 4 of 4 Posts
