1 - 9 of 9 Posts
what is the name of the sensor that the red wastegate line and the green line from the intake go to?
ok what does it do? because i broke one of the tubes that the lines go onto. do i need to replace it asap? will it hurt the truck to run it till the weekend?
owner/president
Do you mean the one on the y pipe(spider)?
yes and no. the one that bolts to the spider with the red and green lines goin to it.not the one that is secrewed into the spider
owner/president
The thing that bolts to the spyder has the MAP sensor vacuum hoses (leftside)and the IAT sensor conn. on the right.
<<< THE GAUGE WHORE...
He is talking about the wastegate valve... Its a non issue. So long as you dont have a intake leak thru the green line dont worry about it.
Discussion Starter #9
ok sounds good
1 - 9 of 9 Posts
