1 - 10 of 10 Posts
Don't know if this has already been posted but here ya go.
Deactivating/activating the BeltMinder feature
The driver and front passenger BeltMinder are
deactivated/activated independently. When deactivating/activating
one seating position, do not buckle the other position as this will
terminate the process.
Read steps 1 - 4 thoroughly before proceeding with the
deactivation/activation programming procedure.
The driver and front passenger BeltMinder features can be
deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set
• The gearshift is in P (Park) (automatic transmission)
• The ignition switch is in the OFF position
• The driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, buckle then unbuckle the
safety belt 9 times, ending in the unbuckled state. (Step 3 must be
completed within 50 seconds after the safety belt warning light turns
off.)
• After step 3, the restraint system warning light (airbag light) will be
turned on for three seconds.
4. Within 10 seconds of the light turning on, buckle then unbuckle the
safety belt.
• This will disable the BeltMinder feature for that seating position if it is
currently enabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds.
• This will enable the BeltMinder feature for that seating position if it is
currently disabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds, followed by 3 seconds with
the light off, then followed by the restraint system warning light
flashing 4 times per second for 3 seconds again.
Not sure if there is a difference in years, but I disabled my seat belt chime a bit differently. I just went under the seat and unplugged the electrical connector going to the seat belt. No more chime or anything.
Exactly rightLOLLOL. I just did this on my buddy's 07 too.
Administrator
:whs:
i have unplugged every one of the new body style trucks we have except for the 08 F350.
MINE WAS A LITTLE DIFFERENT TO TURN OFF. 2003 6.0L
BEFORE STARTING
*SET PARKING BRAKE
*MAKE SURE TRUCK IS IN PARK.
*IGNITION SWITCH IS OFF
*ALL DOORS CLOSED
*DRIVERS SEAT BELT IS UNBUCKLED.
*HEADLIGHTS ARE IN THE OFF POSITION
1.TURN THE IGNITION SWITCH TO THE RUN (OR ON ) POSITION. (DO NOT START THE ENGINE)
2. WAIT UNTIL THE SAFETY BELT WARNING LIGHT TURNS OFF. (APPROX. 1-2 MINS)
* STEPS 3-5 MUST BE COMPLETED WITHIN 60 SEC. OR YOU WILL HAVE TO START OVER.
3. BUCKLE THEN UNBUCKLE THE THE SEAT BELT 3 TIMES, ENDING UNBUCKLED.
4. TURN ON THE HEADLIGHTS AND THEN TURN OFF.
5. BUCKLE THEN UNBUCKLE THE SEAT BELT 3 MORE TIMES, ENDING UNBUCKLED.
* AFTER STEP 5 THE SEAT BELT WARNING LIGHT WILL BE TURNED ON FOR THREE SECONDS.
6. WITHIN 7 SEC. OF THE SEAT BELT WARING LIGHT TURNING OFF, BUCKLE THEN UNBUCKLE THE SEAT BELT.
7. CONFIRMATION OF DISABLING IS PROVIDED BY THE SEAT BELT WARNING LIGHT FLASHING 4 TIMES PER SEC. FOR 3 SEC.
*REPEAT SAME STEPS THE ENABLE
28 cent #2
Mine will start dinging then you just click it once with your finger. its become such a habit i catch it before the ding anways now...
HEARING IMPAIRED
They stopped that in 02. In my 02 I could just click the unbuckle button. In my 03 it didnt work.
HEARING IMPAIRED
BEFORE STARTING
*SET PARKING BRAKE
*ALL DOORS CLOSED
This was the procedure that worked on my 03 7.3 too. Thanks for the post.
Who is Obama?
the first procedure worked for me
1 - 10 of 10 Posts
