1 - 9 of 9 Posts
so I know the rears will bolt in after some drilling and the fronts with a RSK, I have a set of springs from an 02 SD but it had the 5.4. Will they support the 7.3.
STILL LEARNING
It all depends what code there were. You had about 6 different spring choices. You need to know what code there are. there is no makings in the springs to tell you what they are, you need to look at the door jam of the truck they cam from
truck is long gone...thanks, ill see of i can find some numbers of the springs
Im full of win......thanks again, looks like I have paper weights
i gotta get a rsk kit first
From FTE:
2003 manual
Front Springs — F-Series
B — F81A-5310-EA
C — F81A-5310-EA
D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
R — 2C34-5310-AAB, 3,600 lb.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
Y — 2C34-5310-VA
Z — 2C34-5310-WA
It seems that the numbers can vary a bit, but the last three alpha characters seem to be consistent.
AC = U code
AD = V code
AE = W code
AF = X code
1 - 9 of 9 Posts
