1 - 6 of 6 Posts
OK, got my livewire installed and 2 questions about the monitor:
1) Had the monitor hooked up for a few days before my EGT probe came and noticed had some guage going that read "manifold_absolute_f". before I was running tunes it stayed below 30, now its running a bit below 100. I was wondering what this reading even is and if that's normal? Also, I'll get back soon with what the description is when its being monitored, I think it was MAF_PSI, but i'll get back on that
2) Also wondering why my engine coolant temps are so crazy, varies from -260 deg to +160, but never more than that. Anyone else have this issue with the SCT and any ideas?
PSN Pretender
There isn't even a coolant temp sender on the engine, well not for the PCM.
So I would not expect to see it functioning correct.
Cool, that answers one of my questions, Although I wonder what that value is reading? I guess it could be anything if there is some equation for that information that is incorrect.
OEM Moderator
More then one OBD reading device comes up with screwy coolant temps. AE to name one and Interceptor to name another.
Tom
OK, so back to my other question: when I display the manifold_absolute_f in the monitor its name is "map_kpa", so its displaying the map sensors readings i guess, but why is there such a difference in readings between tunes? to reiterate:
Stock tune: didn't get a reading above 30, I think that was at idle and while driving
Performance tune: reading just below 100 at idle and up, not sure how high cuz i wasn't romping on it today, but i did notice it up to 116
Pretty much every reading on mine is goofy. I'm guessing it has to do with units they are measured in or conversion calculations they use. When I tried monitoring ICP or other things I would get numbers that made no sense as far as the readings. I have actual gauges also and even the boost is off and not in a consistent manner so that I could even guess, sometimes off by 5psi sometimes off by 10psi. Trans temp starts out at like 600 and goes down to 300 or something.
1 - 6 of 6 Posts
