1 - 20 of 21 Posts
Old But Sexy
anyone have one in a OBS..how do you like it? what all can you monitor?
Heath
I've had one for over a year now. it monitors most everything tranny temps and voltage, ICP pressure and duty cycle, boost and backpressure, intake temp, batt. voltage and a couple of other things that i never use. the cyl contribution and buzz test are nice and the ability to read codes right away comes in handy. I have been using the 1\4 mile and 1\8 miles times to gauges what happens when I add goodies on the truck. For the price I think it is well worth it
OverFuelingForYourPlesure
I have one, It was money well spent.
it will moniter basicly everything a scanner or AE would.
I leave mine on ICP and engine oil temp most of the time.
IPR duty cycle is also pretty interesting to watch.
In the winter time I watch intake air temp quite abit, It seems to stay real close to outside temp so it is handy that way.
I've had one for over a year now. it monitors most everything tranny temps and voltage, ICP pressure and duty cycle, boost and backpressure, intake temp, batt. voltage and a couple of other things that i never use. the cyl contribution and buzz test are nice and the ability to read codes right away comes in handy. I have been using the 14 mile and 18 miles times to gauges what happens when I add goodies on the truck. For the price I think it is well worth it
I forgot all about the 1/4 mile performance recorder:eek:, I played with that a bit when I first got it but havent touched it since I did all the new mods.
I may have to try it out again:D
OEM Moderator
I also have one and like it a lot.
Winners never quit!
I understand the guage reads Icp but w a sending unit will it pick up Oil pressure and fuel pressure??
yes you can get up to two add on sensors that will read about anything you want
I believe so
THANKS.cool so how would i go about getting the proper probe and sensor tied into the computer for the scan guage to read iT>
The probe and sensor leads go directly to the AUX inputs on the back of the scan gauge.
Cowboy Steve
woo hoo!!!!!!!!!!!!!!!!!! scanguage for me then!
OEM Moderator
It does for the regular stuff.
everything the engine and transmission already have sensors for....
if you add a pyro, fuel pressure sensor, exc. that has to be wired in seporatly to the gauge
1 - 20 of 21 Posts
