1 - 5 of 5 Posts
member
Ok! i got the new scan gauge today with the fuel pressure kit.Where is the best place to tap into the 5v source for this and will the fuel pressure sender screw into the fuel bowl or will i need an adapter? It comes with 1/8th pipe thread.
I don't recall exactly, but I think I bought some option that made the 5v source easier. As far as the adapter for the fuel bowl, http://www.dieselmanor.com sells the adapter to go from the o-ring to the 1/8 pipe. You may be able to find it a local hydraulic shop also. I believe it is #4 boss o-ring to 1/8 pipe. There is an o-ring plug on the passenger side, firewall side, down low on the fuel bowl.
member
Thanks for the help,is there a good place under the dash to tap into the 5 volt source?
member
Anyone know the best place to tap into the 5v source under the dash?
1 - 5 of 5 Posts
