1 - 7 of 7 Posts
Got a question, I plan on adding some after market electronics and was wondering if its safe to drill into the panel right below the a/c vent on the right hand side of the instument cluster or is there wiring or anything behind it. As far as I can tell its open.
Freak'n know it all
turn on the ign, put the trans in low 1, tilt the wheel down. and PULL the panel off.... the radio will come out w it and once it's free from the dash you will need to pop the radio out and unplug about 4 or 5 connections and then the whole panel will wiggle free from the dash... takes me less than a minute to get one off... then you can easily see what you are dealing with and be able to cut as needed... that panel simply pops in and out
Thanks for the input. Sorry it took so long to get back, been trying to get a house ready for sale.
Yep, worked good and all looks clear to do what ever. Thanks.
1 - 7 of 7 Posts
