1 - 16 of 16 Posts
only used on dyno a couple times on a cummins , its a s465 i measured the wheels and the compressor side is 65/91mm exhaust is 83/74 , its in great shape , built legal for most 2.6 kotpa and BOB and some others ,has the protrusion and legal map , price is 800 + shipping
if you want to text me or give me your email ill send some pics
still for sale bump ! make decent offer i want this out of the way .
What kind of injectors would you need to run this?
t4 or t4i housing? t4 I assume? you stuck at 800?
some decent stg 2s would be good , and yes its a t4 flange , i can do better without paypal, its charging too much lol
how much better without paypal? You can PM if you want.
Busy Busy
This turbo works great with 238s and 250/100s.
Completely driveable. Id recommend the largest exhaust housing without a wastegate for the 250s...
this $hit is expensive!
If you could send me some pics I'm interested you can text them to 724 288 6090. Also I will be running 250/100's, will this Turbo struggle or will it be a reliable setup?
Busy Busy
It looks like any other s4 series turbo. Any of the exhaust housings will be fine with those injectors. The larger you go will just net more top end. I have ran the .9 and 1.15. Both completely driveable.
Thanks for all the info Marty, I'm looking to be around the 500hp mark I'm guessing this Turbo would get me there if its capable of running the 250's reliably. Would this be correct?
Busy Busy
Yes. See my thread on psa about the boost/drive numbers.
Discussion Starter #15
to your door Ill do 700+shipping without paypal
Discussion Starter #16
SOLD! thanks
1 - 16 of 16 Posts
