You have the one you need, why would you want to run a different one?can i run a different PCM? current code is PMT1. if so what is the draw backs and what other PCM can i use?
Oops I failed to mention I fried the current one.You have the one you need, why would you want to run a different one?
mine shifts hard itll break tires loose going into 2nd but i also have BANKS trans command:doh: i have to let off when it shifts if at wot sounds like it gonna break somethingShifting programming
