1 - 3 of 3 Posts
STILL LEARNING
Now that i put the smaller tires on my crew cab i am looking to lower it. I currently have a rsk and lift springs. I am looking to lower it using the rsk and the factory OBS springs or V code front springs w factory B code SD rear springs and a 5" block or ICON 5" lift springs. My question is. Do the V codes w the RSK give anymore lift over the stock OBS springs and the RSK?
Not sure as spring condition is a factor..SD springs will get a better ride quality. If you want it lower you can use Excursion front springs..will lower 2"+- over V codes.
What is the height you want?
Using rear 5" Icons ..to be level without a rear block will require X codes with a 3" RS kit..
Have everything you will need..
Cary
STILL LEARNING
On my 97 w a rsk w stock front springs and stock rear springs w a 5" block i was happy w the height.(just wish it had a lil more rake)
I was just looking for a better ride w my crew cab. So if i use my RSK and "V" code front springs will a 5" rear block be enough w "B" code rear springs?. I would like a little rake to the truck, not level
Here is my 97, I wish it had a little more rake to it
1 - 3 of 3 Posts
