1 - 15 of 15 Posts
BrownBrothersPullingTeam
We had a guy drop off his 2000 powerstroke the other day saying it ran rough till it warmed up, we thought no big deal thats most diesels when it cold, but basically, the truck runs a lil rough, and lots of white smoke when you start it up, and i mean alot of white smoke, and once its at operating temperature, the truck runs fine, and no smoke at all....any ideas??
btw, we installed new stock injectors in it a few months back
sounds like plungers sticking in the injectors to me, regardless of wether you replaced them or not thats what it sounds like. also sounds like the IAH is not functioning properly either cause if its not it will blow white smoke from the cold air hitting the hot combution chamber....just steam basiclly and cold burning diesel. if you didnt want to chack the injectors you could try some 5w40 sinthetic oil it will more than likely help it not to stick and run smoother when its cold
Discussion Starter · #4 ·
i was kinda wondering about that, the truck when cold also has a whistle out of exhaust pipe that ive never heard on a 7.3, almost sounds like a tea kettle over a burner, anyways, is it ok to run a full synthetic oil in a truck that has 208,000 miles and never had synthetic in it?? and once you start, it must be ran all the time correct, no going back to 15w40 thanks
no you can switch out and go back anytime you want. as far as the whistle its probably the ebpv closing causing the turbo to make that sound.
Exploding the magma
Yeah you can go back and forth as much as you want...how old are the glow plugs and relay? Are they working well?
Did you scan it? what codes are coming up? Buzz test? I would bet its the injectors sticking.
Beef
:whs: and if it is just a bad glow plug/relay or wiring harness once the motor is warm you're burning the fuel fully.
The 7.3 is picky and mine was hella bad in the MN cold, even plugged in. I had to run synthetic to get decent starts in the winter.
Discussion Starter · #10 ·
im not sure on the glow plugs, i tested the relay and it has power and works fine, and truck fires right up on cold days, so im saying plugs are ok
Discussion Starter · #11 ·
i havent taken it in for buzz test, or to be put on scanner yet, but more than likely will
Discussion Starter · #12 ·
ok thanks on the oil, and the whistle doesnt sound like any ebpv ive ever heard on a 7.3 before, another 7.3 guy in this area said the same thing, that it was a very odd whistle
Discussion Starter · #13 ·
buzz test showed #1 &#7 injectors weak
super tuner
were the stix new or reman?
Discussion Starter · #15 ·
1 - 15 of 15 Posts
