1 - 5 of 5 Posts
My truck has been acting funny at lower rpm's. Whenever I take off it runs rough and shakes a lot . There isnt a whaole lot of throttle response and it lugs on the bottom end until I get the r's up to 2k or more and it still seems rough even up there . Sort of acts like the cps is bad or going bad maybe.
<---F350 DRIFTER
Could be a bunch of things to do that. Check all of your valve cover gasket plugs. I would start there because bottom line 1 or more of your injectors it not firing right or at all. Bad IPR, CPS, pluged fuel filter, bad chip or programs, poorly conected chip if you have one. The list goes on and on.
Good luck
What do I do if the plugs going to the vc on the engine harness are bad? I there anything proper besides replacing the engine harness?
What else?
Yes, you need to either get the repair harnesses from Ford or International, or if you have the capabilities to repin the harness, you can buy the shells and pins so you don't have to buttspice in the pigtail harnesses.
Dave
1 - 5 of 5 Posts
