Like title says, truck is idling rough (I would call it "clunky" but not necessarily out of balance), blowing loads of smoke, and has 1% power. With WOT and two minutes I got it to 30mph. However, it is very smooth under load - it is not vibrating.
The truck: 1995 7.3l F350 with a 1996 front cover on it, 155,000 miles, 1.0AR housing w/WW2 and wastegate deleted, Adrenaline HPOP (5 mo/1000 miles ago), 160/30 FFD injectors (17 mo/6000 miles ago), CPR fuel system (19 mo/7000 miles ago), PHP hydra running economy and high idle.
The truck is parked outside my mechanic's shop. I dropped it off to have the UVCH plugs and IPR plug replaced and U-joints replaced. Ran alright to get there. When he started it up after working on it the present condition manifested.
It is cold and dark in Alaska. Here's what I found after I got off work:
-Fuel filter replaced (filthy, but no help - Fuel was clear with no oil)
-Fuel pressure is fine, even with increased load
-ICP unplug causes a very brief (< one second) change but then business as usual
-Turbo spins fine and has no play
-Truck starts up nice and fast, catches and goes in ~3 turns/sub 1 second
-On start up idle is relatively smooth for 5-10 seconds before getting really rough
-When shifting into reverse or drive rpms drop to 100-250 and the thing sounds like it wants to die. No change in idle in neutral vs park
-Revs right up to 2500 RPM in park, didn't feel rough at all (but is a fog machine)
-EGT sensor reads COLD. 200-300F UNDER LOAD at 2000RPM going down the highway. Sensor is mechanical, not a scangauge.
-Setting tuner to factory, or real factory, and unplugging made no difference in idle
-No change from unplugging EBT sensor
-Setting tuner to DD/economy actually got a little bit of power on the road, but also increased my smoke
-Warming up made no difference in how truck idles or drives
Previous issues I ignored that might be related:
-this summer I replaced the stereo receiver and put in an amp because the old one crackled above volume 10. This had a new problem of radio interference (crackle again) that increased in intensity/frequency with engine load. With a lot of weight it would kick in at maybe 1700 rpm, with none maybe 2000. Taking the tuner off didn't help. I was all ready to choke the hell out of everything when it spontaneously disappeared to never return.
-for the past year RPMs have dropped when suddenly letting off the throttle, e.g. 60mph highway throttle to none. Sometimes they would drop so low engine would die.
My thoughts:
-It doesn't appear to be fuel. Pressure is good, filter is good, pressure doesn't drop under load
-The problem seems to be across all cylinders simultaneously, otherwise why would it run so smoothly under load (albeit with no power) or at high rpm?
-Probably not the CPS? I would have swapped it but didn't bring a spare. Last replaced last summer.
-Maybe the IPR plug is the culprit? I got it off eBay. IPR is as old as the HPOP, so IPR failure seems unlikely.
-Maybe the IDM? It looks stock. I can try pulling it, thawing it, and seeing tomorrow after work. No cool friends with 7.3s to swap with to test.
-If the HPOP conked out I would be surprised - first thing after installing I ran it 360 miles, then 360 back a week later. 21.2 mpg down, 19.8 back. It's driven maybe 400 miles since.
Any ideas? I'm stumped, but I don't know that much about 7.3s. I don't really want to throw parts at it in part because it's -15 out, dark, and the shop is on the bad side of town. Do my conclusions so far seem reasonable? Any help appreciated!
My thoughts:
